Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › indesit idl 530 1st and 2nd lights
- This topic has 13 replies, 5 voices, and was last updated 17 years, 5 months ago by
bishkel.
November 6, 2008 at 10:18 pm #40831
bishkel
Participanthi
my indesit idl 530 dishwasher has flashing 1st and 2nd lights, can anyone tell me what they mean please?
i have tryed switching it off and on but the same thing happens.
there is also water in the bottom, it is heating up the water as it is hot.
any help will be most greatful for.
thanks.November 6, 2008 at 11:09 pm #267682iadom
ModeratorRe: indesit idl 530 1st and 2nd lights
1 + 2 is normally a drain time out error. It can sometimes be a software recognition error but that is not common.
The drain pump on these machines is very prone to jamming due to particles of glass,bone, wood, plastic, sweetcorn etc, etc getting stuck in the pump.
Not difficult to clear, mains plug out, mop out as much as you can from inside and then place a few large towels on the floor. Tip the machine over onto its left side (looking from the front) and remove the base plate. you may need to release the side panels on certain models.
Take note of the connections of the wiring to the float switch and remove plug.
If you then follow the grey plastic outlet pipe into the machine you will find the drain pump.
Removal of the pump is fairly obvious, protect the wiring etc from spillage and you should be able to remove the pump obstruction. Be careful to refit the black ‘O’ ring.
If you think you need help then click the link at the bottom of this post.
February 28, 2010 at 6:41 pm #267683Arkon7
ParticipantRe: indesit idl 500 – 1st green light only.
iadom – YOU ARE A STAR !!!!!!!!!!!! javascript:emoticon(‘8)’)
CoolBIG BIG THANKS. javascript:emoticon(‘:D’)
Very HappyBig thanks from my wife. And I assure you that means something …..
Here in rural France, where the camembert roams free, we don’t get to see white goods professionals very often, thus I was dragged from slumber and thrust into action and your advice was SPOT ON.
This is an IDL500, now 8 years old. The symptoms were when fault first appeared 2 green lights counting from the left, no flashing, hard on. After a reset single green light leftmost illuminates and gentle hum from within and then nothing, except green light.
I removed grey drain pipe and then the drain pump from the sump, and there.. within the impeller was ….. 1cm or 1/2 and inch of walnut shell, insertion of digit and robust shove removed said and impeller moved freely.
Not entirely sure that the ‘spring clip’ on the pipe has reseated nicely, I may have to put a proper jubilee clip on it, but all is well now.
Brilliant, thanks forum, the collective rules !
June 21, 2010 at 9:39 am #267684johnhowell59
ParticipantRe: indesit idl 530 1st and 2nd lights
iadom wrote:1 + 2 is normally a drain time out error. It can sometimes be a software recognition error but that is not common.
Jim,
Will this error code be the same for an Indesit DI620? Light 1+2 flashing rapidly together and water not draining away.Is the repair described above the same for our model?
Many thanks,
JohnJune 21, 2010 at 10:30 am #267685iadom
Yes, same basic innards. 🙂
June 21, 2010 at 12:06 pm #267686johnhowell59
iadom wrote:Yes, same basic innards. 🙂
Thank you for your quick response. Hopefully, we can get it working as quick 😉
JohnJune 23, 2010 at 4:25 pm #267687johnhowell59
Participantiadom,
The pump and outflow pipe were clean with no obstructions!
All put back together and run on 4. This cycle failed with 1+2 lights flashing. Restarted with 1, failed again. Then 3 actually worked to the end with no water left. Then we tried 2 and it has failed again with 1+2 flashing and water in the bottom.
Any other ideas?
Thanks John
June 23, 2010 at 6:58 pm #267688iadom
Sadly it is an Indesit so anything is possible. 😥
If it is emptying correctly then the other fault that is supposed to be shown up by 1 + 2 flashing is a software recognition error, not something I have seen but the Indesit electronics are about the most unreliable on the market so it may be a PCB failure.
Removing the mains plug and checking all of the contacts on the PCB by squeezing them up a little might be worth a try, other than that its time to try a new PCB or go for ‘the other alternative’ 😉
June 23, 2010 at 7:35 pm #267689johnhowell59
ParticipantIadom,
When it failed to finish a cycle it did not empty as well.
Where would the PCB be? In the door?
Thanks again,
JohnJune 23, 2010 at 9:02 pm #267690iadom
If it failed to empty then it suggests the pump needs checking again or may even be faulty.
The tiniest piece of material can block these pumps, it may be a small piece that is floating around in the pump.
Did you remove the pump completely and open it up?
June 26, 2010 at 6:54 am #267691johnhowell59
ParticipantIadom,
The friend that looked at the machine did mentioned that the impellor was free moving. I do not think he opened it up, just spun the impellor from outside.
When the machine fails to complete a cycle, there is water left behind. However, when selecting another cycle the first thing that happens is the water is drained away – gurgling from sink plug hole, and the sump is empty.
So, it seems it may be the PCB then? In the door?
June 26, 2010 at 12:28 pm #267692iadom
PCB is in the door, no real way of testing it though. I would always open the pump up to check, if there is a small object in there it could be sticking intermittently.
Be careful with the inner door edges if you do open it up, they are razor sharp.
June 26, 2010 at 3:46 pm #267693johnhowell59
ParticipantIadom,
Thanks again.
John
July 17, 2013 at 11:51 am #267694Jonhindley83
Excellent advice have never attempted to fix anything like this before but this advice cleared the problem for me
Thanks ALL
