INDESIT IDL 530 – Flashing lights Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › INDESIT IDL 530 – Flashing lights This topic has 4 replies, 2 voices, and was last updated 18 years, 5 months ago by pinkshoes. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts November 21, 2007 at 10:16 am #32378 pinkshoesParticipant My dishwasher has decided to have celebrate christmas earlier by flashing its lights. The wash light and the drying light are flashing. I have looking through the manual but there is no reference to this sequence of flashing lights in the troubleshooting section. Does anyone know what the fault might be ? and if it can be resolved without calling an engineer November 21, 2007 at 4:38 pm #234925 iadomModerator Re: INDESIT IDL 530 – Flashing lights Can you give us the lights by number from the left please. Jim. November 21, 2007 at 7:23 pm #234926 pinkshoesParticipant Re: INDESIT IDL 530 – Flashing lights the lights that are flashing are from the left the 2nd light and the 4th light As it happened just as i was leaving the house this morning, i just switched it off. i will switch it on again when i return home later this evening, and see what happens November 21, 2007 at 11:36 pm #234927 iadomModerator Re: INDESIT IDL 530 – Flashing lights Lights 2 + 4 suggest possible heater failure. could be the heater itself, very prone to failure, could also be the control PCB, wiring breaks etc. Unless you have access to the correct electrical test equipment and the knowledge to use it then it is time to call for help. Try the link below to see if we have someone who can help. Be sure to remove the mains plug if you intend to investigate further. Jim. November 22, 2007 at 9:57 am #234928 pinkshoesParticipant Re: INDESIT IDL 530 – Flashing lights Jim many thanks for your suggestions. I switched it on once i got home, No flashing lights, and it started its cycle at the beginning and completed the cycle without any problems. It must have just been having an off day. I will bear your suggestions in mind in case it happens again, thanks pinkshoes Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
