indesit idl 535!
  • #74524
    ajkwales
    Hiya
    I have unfoutunatley got an indesit idl 535 dishwasher.
    Went to take the dishes out as i thought it had finished
    but it was still dirty water in it..
    There are no light flashing at all but i cant reset it
    either, tried turning it off for a few hours but still
    wont do amything..
    Any ideas please
    thanks
    #391899
    Re: indesit idl 535!
    Are any lights showing when you switch it on and off?
    #391900
    ajkwales
    No the only light that shows at all is the
    red power light!
    #391901
    So there is a light showing then. Could be a main pcb failure. 🙁
    #391902
    ajkwales
    how would i know, and would it be worth repairing?
    thanks again
    #391903
    You would have to isolate from the mains and open it up. Then you would need proper test equipment to check that there is a supply to the main pcb and also visually check the wiring inside the door, it can break where it bends at the bottom.
    It could be a faulty door latch or switch.
    #391904
    fasetester
    make sure to switch of power :plug: before you check or remove any panels could be a blockage in the pump fasetester
    #391905
    iadom wrote:You would have to isolate from the mains
    I think I might have mentioned that fasetester :rolls: also a simple pump blockage would give flashing error messages, it would not leave the machine dead with just the mains indicator light on.
    #391906
    fasetester
    sorry jim for stepping on your toes 😉 fasetester
    #391907
    fasetester wrote:sorry jim for stepping on your toes 😉 fasetester
    No problem, I always wear steel toe caps. :mrgreen:
