Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Indesit IDL 705 Error lights 3H, 6H + F (low rinse Inicator)
- This topic has 5 replies, 3 voices, and was last updated 20 years, 4 months ago by
WSH.
November 21, 2005 at 9:36 am #13454
WSH
ParticipantCan anyone help diagnosing the following error code, the green 3H and 6H lights are flashing and the red light F (Low rinse aid indicator) is on permanently?
What is the error is it possible to fix myself if not then any idea what is involved and approximately how much will it cost.
Thanks in advance
WaynePS.
If it helps this is a relatively new machine purchased June 2004 low level of use i.e. 1 – 2 times a week.November 21, 2005 at 12:04 pm #155000Dave_Conway
ParticipantRe: Indesit IDL 705 Error lights 3H, 6H + F (low rinse Inica
3H + 6H is normally a no drain fault. The rinse aid light is indicating just that I expect, it’s empty ?
Check for blockages around the waste hose/sink trap connection 🙂
November 21, 2005 at 12:34 pm #155001WSH
Thanks for the advice I’ll have a look this evening
WayneNovember 21, 2005 at 10:19 pm #155002WSH
Hi again it doesn’t look like a blockage in the waste pipe.
I removed the hose from the out pipe and ran the first part of the cycle, the washer did not empty so I had to bail it all out again any suggestions would be welcome.
thanks
Wayne🙁
November 21, 2005 at 10:36 pm #155003Dave_Conway
The drain pump may have failed in that case, it maybe time for an engineer to be honest. Not an overly expansive repair should that prove to be the problem.
Check Repairs@ for one 🙂
Power off please if you decide to investigate further yourself :plug:
March 8, 2009 at 6:30 pm #155004emmanneil
i too have the same problem, without the +F(low rinse indicator)
i came home today and i had a pool of water in my kitchen, i cleaned it up and put on another wash to see if it did it again , it did the whole cycle but , as you have guessed it leaked from somewhere again
but now the 3H and 6H light is on at the same time and i can not get any cylce to work now, it starts to fill up with water but then it drains, i have checked the polystyrene float which is ok the outlet pipe is not bent and the pump is empting the water that is going into the machine at the beginning but then it stops with the 3H & 6H lights flashing and if i turn it off and back on after a few mins i can start another cylce but no matter which cylce i choose it does the same.
has anyone got any ideas,
Thanks -
