Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Indesit IDL 730 dishwasher fault
- This topic has 7 replies, 3 voices, and was last updated 14 years, 9 months ago by
BugBlaster.
July 10, 2011 at 9:46 pm #63856
BugBlaster
ParticipantThe washer runs, at end of cycle, no arms have rotated, and light 4 (drying) flashes once a second, while light (Rince aid) light flashes 2seconds on, 2 seconds off. Seems to be some heat in the water, so heater may be ok. Quick look at filters look clean enough. Any ideas/info appreciated,
ThanksBug.
July 10, 2011 at 10:10 pm #355225iadom
ModeratorRe: Indesit IDL 730 dishwasher fault
Ignore the rinse aid, unless you want to use rinse aid, its just telling you the compartment for the rinse aid is empty. 🙂
Light four flashing is A08, heater time out. It could be a heater failing under load, a loose NTC inside the door or a main PCB fault.
A megger across the heater terminals once you have removed the mains plug is the first thing to test.
Both heaters and PCB’s are very prone to failure on these. 😥
Are the spray arms not rotating during the wash cycle if you open the door quickly, is there any water spraying out of them?
July 10, 2011 at 10:53 pm #355226BugBlaster
ParticipantRe: Indesit IDL 730 dishwasher fault
Ran quick cycle again just to check, water heat is ok, the arms do not rotate as they are still in the exact same positon top and bottom as i left them. they both rotate freely, the filter is clean.
July 11, 2011 at 8:36 am #355227iadom
When you say they do not rotate, is there any water spraying out of them if you open the door quickly mid cycle?
If not then its very likely the main pump has failed, quite common but it should still give out an error code. 😕
July 11, 2011 at 7:48 pm #355228BugBlaster
Water gets in there, no rotation on arms, didnt actually see how it gets there. there are pump sounds and water flowing 🙂
Going to take it apart in thenext hour or so and see whats up.July 12, 2011 at 9:43 pm #355229BugBlaster
It looks like the top shelf water intake inlet is missing a rubber grommit into which the upper tray inserts :rolls: . Ive ordered the part from espares. 😀
Thanks for the help
Bug
July 12, 2011 at 10:13 pm #355230kwatt
KeymasterRe: Indesit IDL 730 dishwasher fault
BugBlaster wrote:Ive ordered the part from espares. 😀
Thanks for your support, you could’ve asked as we’re usually a lot cheaper than eSpares. 😉
Also note that eSpares don’t offer any support of the nature you got here.
Sorry but I’m sure you can understand that we like to be appreciated as much as anyone else does and the guys do a sterling job offering free help and advice, we put a lot back into the industry helping the repairers, no other spares supplier does that.
July 24, 2011 at 9:26 pm #355231BugBlaster
sorry, shold have looked here but googled them first. they did take forever to get the part to me, 7 days for a small packet from the Uk is a bit long, usually 2-3 days. and charged international rates intead of royal mail small packet rate!!! not happy!!
