indesit idl350 water ingress
Home Forums Public Support Forums Help And Support Dishwasher Help Forum indesit idl350 water ingress
  • #53746
    yandownie
    My Indesit Diswasher is leaking water inside.there is a water inlet in the top left hand corner and this is where the water leaks in whilst the machine is not in use.
    if the machine is used daily it isnt much of an issue as the machine drains before it starts a full cycle but if left for a couple of days the water threatens to overflow
    Is this an easy enough repair ? what part is the most likely culprit ?
    thanks in advance.
    #317063
    Re: indesit idl350 water ingress
    Do you mean an IDL530…?
    Faulty water inlet valve is the only thing that can cause the machine to fill from that area when switched off.
    The inlet valve is the thing that the fill hose is screwed onto.
    #317064
    yandownie
    yes sorry for the incorrect model number.i will investigate that part over the week and post result on here for the benefit of others too.
    #317065
    TBH you can’t really invesitgate the part, you just have to change it. 😉
    Part number C00110611.
    #317066
    yandownie
    job sorted ,you were spot on with diagnosis.ordered the part and it fitted easily enough,tested,no leaks wife happy lol.
    thanks
