Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Indesit IDL40 Dishwasher – 1st green light flashing
- This topic has 7 replies, 2 voices, and was last updated 15 years, 8 months ago by
susywoozy.
August 23, 2010 at 4:52 pm #56730
susywoozy
ParticipantIndesit IDL40 Dishwasher – Problem is the 1st LED light started to flash at the end of the cycle. Next time I tried to use it, it wouldn’t fill with water or even start the programme. The 1st green light is still flashing. Can anyone offer advice.
August 23, 2010 at 5:52 pm #328625iadom
ModeratorRe: Indesit IDL40 Dishwasher – 1st green light flashing
Flooded base, could be an internal leak or oversoaping. Using combination tablets in these machines is a common cause of oversoaping.
You should also avoid opening the door in the middle of a cycle.
Drag the machine out and after placing a few towels on the floor and removing the mains plug, tilt the machine to one side.
If water does run out that confirms the base is flooded. Allow it to dry out for 24 hours and then try it again.
If it fails in a short space of time then you have an internal leak that needs investigating.
August 23, 2010 at 6:30 pm #328626susywoozy
ParticipantRe: Indesit IDL40 Dishwasher – 1st green light flashing
Hi Many thanks for replying promptly…. It was drained once but after tilting on side again it is full of water… Where would I start first to look for the leak???? Husband has looked at pump and that is fine
August 23, 2010 at 6:34 pm #328627iadom
If it is filling up that quickly it should be obvious. The main circulation pump can leak, also the lower spray arm assembly can ‘unscrew’ in the base of the machine.
That one is easy and just needs slotting back in and tightening up. There is also a small flow meter that sits just under the drum, I have seen those pop right out of the hose above the circulation pump.
It could be overfilling leading to a leak into the base as well, several possibilities TBH.
BTW, does the full model number have a large letter C at the end?
August 23, 2010 at 6:44 pm #328628susywoozy
Hi the model number is IDL.40.UK.C
August 23, 2010 at 6:46 pm #328629iadom
Oh dear. 😥
Manufactured by Wuxi Little Swan in China. :rolls:
August 23, 2010 at 6:59 pm #328630susywoozy
That doesn’t sound too good. Will pass on the information and fingers crossed. Hope you don’t mind me getting back to you to let you know either way whether it is sorted.
Many thanks
😉August 23, 2010 at 7:04 pm #328631iadom
Please do, if its a simple problem then worth sorting, if the main circulation pump is leaking then it might be time to invest in something a little better. 😉
