Indesit IDL40 was first 2 lights now just light 1
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit IDL40 was first 2 lights now just light 1
  • #61146
    allan73
    I was called to this with lights 1&2 flashing and I removed a chip of pottery from drain pump, job done I think. Turns out customer has removed a blanking nut from within the main cavity without telling me and not put it back 😡
    Can anyone tell me if there should be an o-ring inside this, as there isn’t and the customer can’t remember seeing one ?
    #345001
    Re: Indesit IDL40 was first 2 lights now just light 1
    Not entirely sure what “blanking nut” you’re referring to but all the same all connectors/components to and from the tub each have their respective O ring. So yes whatever it is it needs an O ring.!
    #345002
    allan73
    Thanks Martin, I think the “nut” is described as overflow bodytop.
    #345003
    allan73 wrote:Thanks Martin, I think the “nut” is described as overflow bodytop.
    Got ya! In that case the O ring for it is = C00075695 🙂
