indesit idl40s
  • #59402
    timofleeds
    Hi can anybody help with our problem? We have the above model but it does not heat up. After a cycle we are left with number 4 warning light left on. Any help would be most welcome.
    Tim
    #338044
    Re: indesit idl40s
    A quick trawl through this forum will soon reveal that this is a very common fault on Indesit dishwashers.
    In 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of cases it is either the heating element or the control PCB that has failed.
    As yours appears to have the ‘L’ shaped element that is visible inside the tub, it is more likely to be the PCB on your machine.
    The first step is to unplug, remove the baseplate and test the element with a suitable multimeter or megger for continuity/resistance/insulation.
    A couple of different PCB’s used, full serial number needed to identify. Is there a letter C after the model number?
    #338045
    timofleeds
    Re: indesit idl40s
    Hi Thanks for the fast reply, the other numbers are UKC and LS08-EV03C.
    I had seen other post but most mention 2 warning lights not just the one.
    Many thanks Tim
    #338046
    Re: indesit idl40s
    The dreaded C 😥 Made in China. :rolls:
    Light four is definitely a no heat fault.
    Thats not the serial number BTW, its an eight digit number ( no letters ) at least.
    #338047
    timofleeds
    Re: indesit idl40s
    thanks the serial no is 612088072
    many thanks Tim
    #338048
    Re: indesit idl40s
    If you do decide to buy a PCB its a C00142139. Be sure to test the heater first though. 😉
    #338049
    timofleeds
    Re: indesit idl40s
    Many thanks Iadom.
    Tim
