Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Indesit IDL50 3rd LED Blinking
- This topic has 9 replies, 2 voices, and was last updated 10 years, 4 months ago by
Pepo.
December 15, 2015 at 1:01 am #87039
Pepo
ParticipantHi all !!
I have a problem with a Indesit IDL50 dishwasher. In every of the 5 programs the machine first drain the water inside and after 1 or 2 minutes the 3rd LED starts to blink and drain pump continue running for about 5 minutes.
Nothing more occurs, is not taking water.I’ve been checked the water intake E.V. presostat, main pump and so one. All seems O.K.
Could be a thermostat problem?
Thanks in advance.December 15, 2015 at 9:32 am #433773iadom
ModeratorRe: Indesit IDL50 3rd LED Blinking
Wrong model number, could it be an IDL500 ?
Error code is a faulty ntc which is hard wired to the control module, a few different versions of this machine including a Chinese made one. :rolls:
All the numbers from the rating plate on the side of the inner door needed to ID but at least one of these modules is around £80.00
December 18, 2015 at 12:39 am #433774Pepo
ParticipantRe: Indesit IDL50 3rd LED Blinking
Thanks for your reply. The model number is correct IDL50, is an Spanish model.
The number inside the electronic model is:
21010324500 – S1
ID 1020051 FT04265December 18, 2015 at 12:41 am #433775Pepo
Sorry, I mean the electronic circuit board inside the door.
December 18, 2015 at 9:03 am #433776iadom
The numbers on the circuit boards mean nothing as far as parts identification goes and the parts recognition software we have is for UK sourced machines only. 🙁
December 19, 2015 at 10:10 am #433777Pepo
Hi, iadom .
When you says “hard wired” you mean it’s connected to the electronic module via a wire?
I can see a black 2 wires cable, one of them with a white discontinous strip, going out from the module. Is this the thermistor cable?
December 19, 2015 at 10:32 am #433778iadom
It is usually the two thin black wires that go to the thermistor, the thermistor is not available as a spare part. 🙁
December 19, 2015 at 6:29 pm #433779Pepo
Thanks again !!
I have found a new module for about 100€ but I also have a lot of NTC’s at home for other uses so If I can know the specifications of the original NTC maybe can found some other that works.
I only know that at 20ºC must read about 20KOhm at the meter.
December 19, 2015 at 7:23 pm #433780iadom
As the ntc is not even listed as a part and your model number does not correspond to any UK models it is nigh on impossible for us to tell you that.
December 20, 2015 at 9:13 am #433781Pepo
O.K. Thanks for your help.
I’m gonna buy a new module to solve the problem.
