Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit IDL500 dishwasher flashing lights.
- This topic has 4 replies, 3 voices, and was last updated 16 years, 1 month ago by
aqualectric.
February 28, 2010 at 10:42 pm #52865
aqualectric
ParticipantIndesit IDL500 dishwasher. 37300400000. Serial no:- 111141085.
Set to any program, start , machine pumps, fills…..then lights 1 and 3 flash and the machine drains and beeps. Lights are difficult to cancel.
The UKW fault book shows 1 + 3 to be filter blockage. Filters are clear and pressure pipe is clear, pressure chamber seems clear also.
So I thought, Bit100 PCB… notoriously unreliable……and ordered a new one. Same fault on new PCB. Although the new PCB didn’t match the old one in any way, well OK, it looked the same. Every number on the labels was different; even the one printed on the PCB itself.
Could it be the flowmeter? I’ve only just thought about that…… 😳With the Bit100 PCB’s failing continuously now, is there any surefire way of getting the right one for the machine you order it for? I have ordered 3 PCB’s from Connect of late and only one worked as it should. There are more than one for each machine and the numbers on the label stuck to the boards never match the original. I am very confused as to how you can ascertain what you have is in fact what you need. Connect’s description and info is not at all clear and sometimes no info at all is shown. It then becomes almost a lottery to get the right one.
Is there any other way of identifying these boards and what do the numbers on the board labels actually refer to?? 😕Any help appreciated!!
Thanks,
Steve.
February 28, 2010 at 10:49 pm #313454iadom
ModeratorRe: Indesit IDL500 dishwasher flashing lights.
Correct part number for that machine is C00143207. It has had some changes from the original which give some slight variations to the performance but it should be interchangable.
There are however three different models of the IDL500. Its probaly best to ask on here first before trying Connect.
Check your inbox. 😉
March 1, 2010 at 12:35 am #313455Penguin45
ParticipantRe: Indesit IDL500 dishwasher flashing lights.
The filter blocked error code normally relates to the high pressure switch above the outlet from the circulation motor – fills up with gunge and won’t switch.
March 1, 2010 at 1:23 am #313456aqualectric
But the program doesn’t even get to run the wash motor – it is almost like it is sensing an overfill situation. Wouldn’t the motor need to be running and pressurising to operate that switch?
Thanks for the replies,
Steve.
March 2, 2010 at 8:29 am #313457aqualectric
Belated thanks for the info, Jim!! 😉
Steve.
