The Top Spray arm on my IDL500 will not go round – I changed to nut and seal that it connects into and have checked it is clear of debris etc but it will not go round – the dishwasher is only 2 years old
It rotaes freely – it seems to drop a one end and get stuck on the tray.
I changed the nut at the back that has the seal on it – made sure it is not blocked – I am thinking it maybe a pressure problem – lack of water getting to the topspray arm.
jov
put d/w on any programme, let it run for a minute or two until you can here it in wash action…this gives the main wash motor time to fill and pump the water around the d/w…then open the door slightly and see if the top arm is moving. this would indicate if the wash motor is strong enough.
richard
