INDESIT IDL530
  • #29401
    trainer
    Hi, Dishwasher performs as it should but with no heat. Doesnt stick on programme. Heater and safety stat both tested ok. Module???.
    #222990
    Martin114
    Re: INDESIT IDL530
    Hi trainer,
    I had this problem before which was cured by replacing module with ntc attached.
    Cheers
    trainer
    Re: INDESIT IDL530
    Thanks Martin,
    Do you remember if it was part no c00143209? Thanks,
    Rob
    #222992
    Re: INDESIT IDL530
    Correct . 😀
    senseib
    Re: INDESIT IDL530
    Always a good idea just to check for a dry joint at heater connection first, before ordering new one.
    Common fault these days!
    Brian.
    #222994
    trainer
    Re: INDESIT IDL530
    Brian, Thanks… spot on about the dry joint.
    Rob
