Indesit idl530
  • #59302
    Steven
    Have a fault error code of the second led (which relates to valve)
    The machine will fill ok on pre rinse, wash motor circulates!
    Then when you start main wash starts to fill, starts to circulate, continues to fills then the second light comes on cuts out and drains off?
    No leaks, heater, stats and pumps tests ok.
    If reset will do pre rinse again ok?
    Any suggestions why it show a valve fault when the valve is working (dont say becuase its indeshit) 😆
    Cheers
    Steven
    #337635
    Re: Indesit idl530
    Did you check the heater for insulation, it will sometimes throw up this fault when the heater is even slightly down to earth.
    Other than that its because its an Indesit. 😆
