Re: Indesit IDL700 – stopped working mid wash!
Error codes for these are indicated by flashing lights so any possible suggestions are guesswork.
As it is not emptying then checking the drain pump and outlet hoses etc would be the obvious place to start.
Access from underneath, remove the mains plug, bale out as water as you can then place several large towels on the floor and tilt the machine over onto its left hand ( from front ) side.
Take off the base and the drain pump is right in the middle, follow the grey plastic outlet pipe into the machine to find it.
