Indesit IDL700 water in bottom of machine will not drain
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Indesit IDL700 water in bottom of machine will not drain
  • #19483
    Avon
    This D/w is just out of the standard 12 months warranty and has just developed a fault. Basically it won’t start and there is water in the bottom. I have checked the hose for kinks, checked the filter for blockages- none.
    What else could be the problem? When turn it on, the front panel makes a low hummimg noise but nothing else.
    The water in the bottom appears to be cloudy.
    #183349
    Re: Indesit IDL700 water in bottom of machine will not drain
    Almost certainly the drain pump is blocked and will need removing and clearing. Help to sort that out for you from a local independent engineer in your area, simply click on the link below. 🙂
    #183350
    Avon
    How much are we talking approx, i.e callout, parts and labour ?
    If it is over £100 Its not worth it as I only paid £170 brand new 13 months ago.
    Thanks for your advice anyway.
