Indesit IDL705 – water not heating
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Indesit IDL705 – water not heating
  • #52697
    viv49
    IDL705 S UK2
    The machine completes the cycle, no error codes/flashing lights, but the dishes are wet through and no heat is present at the end of the cycle.
    Your help will be greated appreciated.
    #312802
    Re: Indesit IDL705 – water not heating
    Difficult one, this machine has the exposed element inside the tub which is not as prone to failure as the internal, tube type heater. The PCB is very prone to failure on these machines but a no heat fault usually displays an error code.
    Mains plug out and a continuity,resistance and insulation check on the heating element first. After that its hit and hope by changing the PCB. 😥
