Hi all
Can anyone confirm what the Wash and End lights flashing means, I wasn’t sure if it was the same codes as the fdl570 or not as it only has the 3 lights in a line.
Annoyingly this machine has an intermittent fault, it will drain then fill before bombing out with the error at the end of the fill, When it does run it is perfect. I have already changed the flow meter as I thought that that was the problem but it is still doing it.
Any info would be much appreciated.
Thank you
Jem
