HI i have a indesit idv65 dryer,The shaft on the drum has broken and also the bearing has worn down,
the problem is i cant see any screws inside drum to take off broken shaft if i cut off broke shaft can i fix one off the replacement shafts to the drum.
regards peter.. :rolls:
