Indesit IDV75UK Tumble Dryer Bearing
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Indesit IDV75UK Tumble Dryer Bearing
  • #98461
    Phaeton
    Can anyone tell me the difference between
    https://shop.ukwhitegoods.co.uk/bkt102-compatible-tumble-dryer-drum-repair-kit
    and
    https://shop.ukwhitegoods.co.uk/c00305794-tumble-dryer-drum-repair-kit
    Apart from £4, is one a better quality both state they fit the IDV75
    #472439
    the dearer one is a genuine manufacturers part
    the other is a part made by someone else to do the same job
    if it was me i would use genuine parts
    first question with all hotpoint dryers is was this unit modified by hotpoint during the recall ?
    Phaeton
    Thanks Dave, I agree with you for £4 I’ll go with the genuine part, although it’s supposed to come with a 10 year parts warranty & only 4 years old, I’m going to give the manufacturer a ring Monday, but I suspect it’s parts only so will have to pay for the labour which will be more than the part. Ridiculous design, the last dryer died in exactly the same way.
    Alan..
    #472441
    you would have to pay for labour and it would be cheaper to get a local guy in
    also what i asked is, was the machine modified during the recent racall, at 4 years old its ony the edge of where they pre modified them in production
    Phaeton
    Sorry Dave I missed your question, yes, they sent an Engineer out a couple of few ago not quite sure what he did other than a brace across the back of the unit, but he had it stripped down for 30-45 minutes so I presume he did extra work inside, I ws working so didn’t watch him. Alan,
    #472443
    that ok then because if it was not done they are now replacing the driers
    Phaeton
    Does this look repairable, or has it gone too far, no point in buying a new bearing if it’s just going to fail again.
    #472445
    it will be fine.
    just fit new shaft and bearing
    this is quite common
    Phaeton
    Thanks Dave, thought it would be, but nice to get the confirmation, Indesit BTW don’t think this is a design fault, and that it’s acceptable for it to fail in 4 years. Alan..
    #472447
    well if you consider this is the only design that has a rear bearing fail constantly including the cheaper models then its a very poor design
