Indesit IFW6340ixUK not fully heating up
Home Forums Public Support Forums General Enquiries And Questions Indesit IFW6340ixUK not fully heating up
  • #102985
    ChrisMac
    Hi, I have an Indesit oven IFW6340ixUK (759991026700) which has a heating issue. It only heats up to about 120 degs C
    I have replaced the element and the Temp probe but still have the issue of the oven not heating up
    Any advice?? the Temp probe on this plugs into the rear facia panel by the temp knob. could the motherboard? be faulty. if so where to get the part from.
    thanks CHRIS
    #491345
    is the cooling fan running ?
    ChrisMac
    Hi Dave
    ​​​​​​YEs the cooling fan is working fine
    Thanks Chris
    #491347
    if it is a control panel fault you cant do it yourself
    panel comes with no software and has to be programmed
    ChrisMac
    Hi Dave, is there anything else i might be able to look at or is this the one that has to be done by Indesit directly.
    thanks CHRIS
    #491349
    well as an engineer I would be measure voltages at the heater
    we need to try and acertain if the board is turning off the heater or is it something else like an overheat stat
    ChrisMac
    All sorted thanks. Indesit fitted a new control board
