Indesit IS60V Fan Scraping against Rear panel
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Indesit IS60V Fan Scraping against Rear panel
  • #83211
    TheFlamingRed
    Afternoon all.
    For the last couple of days, our tumble dryer has been making an ever increasing squeezing noise. Last night, we took it to pieces to see if we could find a problem, and we did. The drum rotations feels fine, the belt looks in very good condition and the motor shaft rotates fine.
    The problem is that attached to the rear of the motor shaft, are fan blades that push air through a heating element and into the tumble dryer itself. These blades are now touching the metal plate located on the back of the Dryer. I’ve sketched a diagram as an attachment.
    I’ve been thinking of ways to fix it, as I don’t really want to be messing around too much of the motor (on first glansce, it appeared a sealed unit but I didn’t try to take it to pieces). I’ve considered adding a few washers to the fixings on the back plate, to move it out of the fans reach. However, that will mean there will be small gaps at the back that will disrupt the air flow – which I assume is bad. I Coulld Duct tape it up, to foil tape it up, but as this area also encloses the heating element, will this be a fire hazard?
    I can’t see many other methods to fix it. Any advice is greatly appreciated.
    Red
    #422057
    Re: Indesit IS60V Fan Scraping against Rear panel
    from what i can see this is a metal fan
    answer carefully bend the blades just enough so it does not touch and try to bend them as equal as you can
    you have to first decide if its touching the cover or the casing. if its the cover, has the cover been damaged pushing it closer to the fan
