Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit IS60VUK T/D: no start?
- This topic has 5 replies, 3 voices, and was last updated 18 years, 4 months ago by
trusted.
December 11, 2007 at 12:13 pm #32923
trusted
ParticipantHi, can someone help please.
I have been asked to look at an Indesit IS60VUK 95306290000 60717803 Tumbledryer. Power is getting to the machine, but when you press the start button there is no relay click and the machine does not not start.
I have checked the start switch and that is okay.
Anyone any bright ideas?Best regards,
Alan.December 11, 2007 at 2:12 pm #236822senseib
ParticipantRe: Indesit IS60VUK T/D: no start?
Door lock & pcb assembly perhaps?
December 11, 2007 at 6:57 pm #236823trusted
senseib wrote:Door lock & pcb assembly perhaps?
Thanks for that senseib.
I have found the door interlock on Connections, but they are out of stock of the relay board. In view of the lack of relay “click” when the start button is used do you think it’s the relay board that I need?
Best regards,
Alan.
p.s. are these the correct part numbers
1702778
C00141683December 11, 2007 at 7:50 pm #236824hotpnt
hi, the relay would only click if the door lock was closed, only way to check is by-pass the lock
December 11, 2007 at 10:16 pm #236825senseib
trusted wrote:
senseib wrote:
Door lock & pcb assembly perhaps?Thanks for that senseib.
Best regards,
Alan.
1702778 Stock code: 204550 £11.62+
C00141683 Stock code: 249677 £16.45+Part numbers are correct – both available at Qualtex see stock codes above. Suggest you follow hotpnt’s tip first before ordering.
Brian.
December 12, 2007 at 8:40 am #236826trusted
Best regards,
Alan.
Brian.
Thanks to both of you. I will have another look at it.
Those prices are very interesting.
1702778 PCB RELAY from Connections will cost me £13.79+(no stock) and thro Masterpart £13.27+
C00141683 DOOR INTERLOCK ASSY from Connections will cost me £19.53+ and thro Masterpart (MDA1703327) £14.99+.
