Indesit Is70c condenser tripping
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit Is70c condenser tripping
  • #60506
    bmrenr
    Hi I have the above m/c tripping the rcd.This is happening because water is getting into the housing for the heating element and the circulating fan which is blowing the water up to the heating element and in turn tripping the rcd.I have read posts about this happening to other dryers and they give this part no c00264260 for a housing with an absorbent pad.Does anyone know if this fits my m/c or has anyone had this prob and sorted it?
    All help greatly appreciated.
    Tom.
    #342494
    pup
    Re: Indesit Is70c condenser tripping
    hi tom
    check pump and check for blockage fairly easy to repair
    #342495
    Fluff blockages in the pump or pump itself (C00264640) needs changing, or better still BOTH! Dependant on serial number it may also need a modified float kit?
    #342496
    bmrenr
    thanks guys, have checked pump and seems to be working fine, also have cleaned channel from pump to condenser no blockages, might try a new pump and see how it goes, thanks again for your replys . tom
