Indesit IS70C. Installing new jockey pulley.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit IS70C. Installing new jockey pulley.
  • #53452
    Just went to this today. No drum rotation. Took off top and found belt was still on. Took off side panel and found jockey pulley was kn@ckered, belt had slipped off it and was not being driven.
    Question is, is it possible to install new pulley, which comes with bolt-on-to-motor bracket, without removing drum etc.? Doesn’t look like there’s a lot of room in there.
    Mike.
    #316066
    deltra
    Re: Indesit IS70C. Installing new jockey pulley.
    yes you can 😀 take off side panel,then release plastic cover that is over the fan, then release plastic fan(pliers to release spring clip)now you have pleny access to jockey wheel. 8) one of the easier jobs on an indesit 😈
    #316067
    Ah, I see. Thankyou.
    Mike.
    #316068
    Did this yesterday. Your method worked a treat. Thanks again for that.
    Mike.
