Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit is70c / tripping electrics
- This topic has 6 replies, 4 voices, and was last updated 14 years, 6 months ago by
shaun67.
September 23, 2011 at 2:32 pm #65244
shaun67
ParticipantIndesit is70c s/n 601200301 / 95306170000
Looked at this dryer today as it was tripping electric..
Found faulty heating element and loads of fluff everywhere ..pic of dodgy element
http://i1111.photobucket.com/albums/h47 … 122132.jpg
Also needs new belt ..any tips regarding fitting new belt on this ,first time on one of these. 😆
September 23, 2011 at 2:41 pm #359809iadom
ModeratorRe: Indesit is70c / tripping electrics
Belt change is an ‘arse’ of a job. 😥
Getting the new belt back over the jockey pulley is the hardest bit, some people use the old belt looped around the new belt to heave it over the pulley.
I have tried different ways, sometimes feeding the belt around the drum and motor shaft with the drum at the side of the machine and then turning the drum into place.Send me an e-mail address via PM and I will send you some info.
Must add, I have never used the method given in the service manual which involves loosening the motor.
Its one of those jobs that you just have to have a go at and work out which way is best for you.
PS. Check the rear bearing and shaft. 😉
September 23, 2011 at 3:02 pm #359810loopey
ParticipantRe: Indesit is70c / tripping electrics
try this iadom very easy to do.
take the screw out of the jockey pully the one neatst the side panel unscrew the the other one untill it can be un hooked from the motor , place pully around belt one big heave
and hook the jocky pully back in place the screw acts like a hinge , screws back in and yer done …September 23, 2011 at 3:05 pm #359811shaun67
Cheers Jim , pm sent …Looks a cow of a job that’s why i thought I’d ask 🙁
September 23, 2011 at 3:49 pm #359812iadom
I would say the White Knight condensor dryer belt change is worse. :rolls:
September 23, 2011 at 4:38 pm #359813shaun67
Thanks Jim,
Got the email ..gonna have a read now 😀
shaun
iadom wrote:I would say the White Knight condensor dryer belt change is worse. :rolls:
I had to use a hammer to get them bloody clips back on the motor bracket on a white knight dryer ..took me longer to get them on than to strip it all down and clean everything in sight 🙂
September 23, 2011 at 5:02 pm #359814A1engineer
loopey wrote:try this iadom very easy to do.
i do it this way, peice of piss with old belt, new belts are a bit trickier but still by far the easiest way to do it -
