Hiya
I have an Indesit ISL70C Condenser Dryer and I’ve had no end of trouble with it making a lot of noise. Now that’s fixed it keeps tripping the fuse. Any ideas?
JillyB
The most common cause is water getting onto the heater elements, possibly needs a good clean out of the float chamber and the elements drying off with a hairdryer. Not an easy machine to DIY, plug out if you intend to dive inside or try the link below to see if we can help.
One thing I forgot to mention is make sure the condensor is also clean, not as easy to see through as the earlier type, a pressure washer or garden hose is the best way to clean that out.
If the above doesn’t work from experience i find it’s the heater that shorts out on these models and would need a new element.
Just curious what was making the noise.Was it the fan inside?
Thank you for that. The noise fault was from new and it seems that the drum hadn’t been centered. If you want a more detailed explanation let me know and I’ll get my other half to reply.
Jilly B
