Indesit ISL70C Condenser Dryer Beeping
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit ISL70C Condenser Dryer Beeping
Viewing 15 posts - 1 through 15 (of 21 total)
  • #35514
    kirkie
    For some strange reason my dryer is starting to play games. If I press the start button it just beeps. I have emptied the water cleaned the condenser filter at the bottom and also the fluff filter inside. Can anyone offer any suggestions please other than replacement…..
    #246883
    Re: Indesit ISL70C Condenser Dryer Beeping
    Are any of the lights on the front flashing?
    #246884
    kirkie
    iadom wrote:Are any of the lights on the front flashing?
    No, none are flashing. The red power light is on and so is the empty water filter light.
    #246885
    It could be a simple door switch fault, is the little plastic peg still attached to the inside of the door at around 12 o’clock?
    kirkie
    iadom wrote:It could be a simple door switch fault, is the little plastic peg still attached to the inside of the door at around 12 o’clock?
    It appears OK, but the door does have a tendency to open when the dryer is on. I presumed this could be down to the amount of washing inside.
    #246887
    Not the most robust door mechanism, the only way forward is to check the door switch is operating correctly before getting to the expensive bits. 😉
    Mains plug out and a test meter required.
    jim.
    #246888
    kirkie
    iadom wrote:Not the most robust door mechanism, the only way forward is to check the door switch is operating correctly before getting to the expensive bits. 😉
    jim.
    Is there any other way of testing it as I have no test meter, unless you can point me in the right direction of buying one and then a crash course on how to use it….
    #246889
    kirkie
    I do have one of these, but don’t know what to do with it…..
    http://www.screwfix.com/app/sfd/cat/lrg … l&ts=66381
    Sorry for being thick….ha ha…
    #246890
    Put it back in the drawer, not a safe tool to use at the best of times. 😯
    Please do not live test, there is no need whatsoever.
    At this stage I would suggest calling in someone who has the correct equipment etc. Why kill yourself trying to save a few £££’s. 😥
    Better thick (you said it not me) than dead. 😉
    The door switch is not very expensive if it is at fault.
    stripey
    It could also be the float switch that is at fault. It is on the rear of the machine bottom RHS it could be stuck, it is worth checking.
    #246892
    kirkie
    I will check that too…
    #246893
    kirkie
    I had a look and saw what all I can describe is a metal strip. Other than that I have no idea….
    #246894
    helo_75
    except the float switch would only stop it heating, nothing more
    id tend to agree with jim, get someone in, its safer
    please do yourself a big big favour
    #246895
    stripey
    helo_75 wrote:except the float switch would only stop it heating, nothing more
    The float switch also brings on the empty water light and can lock al the controls up.
    #246896
    kirkie
    Thanks guys I will try the yellow pages tomorrow as Indesit offer the following:
    Our fixed rate repair charge makes life easy: repair charges from just £99.98 (or €114 in Eire)
    A one off repair charge with no hidden extras
    Convenient, cash and hassle free service
    Repair cost includes callout and ALL parts and labour
    Your whole appliance is guaranteed for 14 days
    Pay monthly options available
    Repair is guaranteed for 12 months
    We only use genuine Indesit parts
    Who better to repair your machine than the people who built it?
    Unless anyone can recommend someone in the East Yorkshire area….
