Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit ISL70C Condenser Dryer Beeping
- This topic has 20 replies, 4 voices, and was last updated 18 years ago by
kirkie.
March 25, 2008 at 3:46 pm #35514
kirkie
ParticipantFor some strange reason my dryer is starting to play games. If I press the start button it just beeps. I have emptied the water cleaned the condenser filter at the bottom and also the fluff filter inside. Can anyone offer any suggestions please other than replacement…..
March 25, 2008 at 5:05 pm #246883iadom
ModeratorRe: Indesit ISL70C Condenser Dryer Beeping
Are any of the lights on the front flashing?
March 25, 2008 at 5:09 pm #246884kirkie
ParticipantRe: Indesit ISL70C Condenser Dryer Beeping
iadom wrote:Are any of the lights on the front flashing?
No, none are flashing. The red power light is on and so is the empty water filter light.
March 25, 2008 at 5:15 pm #246885iadom
It could be a simple door switch fault, is the little plastic peg still attached to the inside of the door at around 12 o’clock?
March 25, 2008 at 5:20 pm #246886kirkie
Participantiadom wrote:It could be a simple door switch fault, is the little plastic peg still attached to the inside of the door at around 12 o’clock?
It appears OK, but the door does have a tendency to open when the dryer is on. I presumed this could be down to the amount of washing inside.
March 25, 2008 at 5:25 pm #246887iadom
Not the most robust door mechanism, the only way forward is to check the door switch is operating correctly before getting to the expensive bits. 😉
Mains plug out and a test meter required.
jim.
March 25, 2008 at 5:32 pm #246888kirkie
Participantiadom wrote:Not the most robust door mechanism, the only way forward is to check the door switch is operating correctly before getting to the expensive bits. 😉
jim.
Is there any other way of testing it as I have no test meter, unless you can point me in the right direction of buying one and then a crash course on how to use it….
March 25, 2008 at 5:33 pm #246889kirkie
ParticipantI do have one of these, but don’t know what to do with it…..
http://www.screwfix.com/app/sfd/cat/lrg … l&ts=66381
Sorry for being thick….ha ha…
March 25, 2008 at 5:59 pm #246890iadom
Put it back in the drawer, not a safe tool to use at the best of times. 😯
Please do not live test, there is no need whatsoever.
At this stage I would suggest calling in someone who has the correct equipment etc. Why kill yourself trying to save a few £££’s. 😥
Better thick (you said it not me) than dead. 😉
The door switch is not very expensive if it is at fault.
March 25, 2008 at 6:07 pm #246891stripey
kirkie wrote:
iadom wrote:
Are any of the lights on the front flashing?No, none are flashing. The red power light is on and so is the empty water filter light.
It could also be the float switch that is at fault. It is on the rear of the machine bottom RHS it could be stuck, it is worth checking.
March 25, 2008 at 6:19 pm #246892kirkie
ParticipantI will check that too…
March 25, 2008 at 6:35 pm #246893kirkie
ParticipantI had a look and saw what all I can describe is a metal strip. Other than that I have no idea….
March 25, 2008 at 7:06 pm #246894helo_75
Participantexcept the float switch would only stop it heating, nothing more
id tend to agree with jim, get someone in, its safer
please do yourself a big big favour
March 25, 2008 at 7:17 pm #246895stripey
Participanthelo_75 wrote:except the float switch would only stop it heating, nothing more
The float switch also brings on the empty water light and can lock al the controls up.
March 25, 2008 at 7:21 pm #246896kirkie
Thanks guys I will try the yellow pages tomorrow as Indesit offer the following:
Our fixed rate repair charge makes life easy: repair charges from just £99.98 (or €114 in Eire)
A one off repair charge with no hidden extras
Convenient, cash and hassle free service
Repair cost includes callout and ALL parts and labour
Your whole appliance is guaranteed for 14 days
Pay monthly options available
Repair is guaranteed for 12 months
We only use genuine Indesit parts
Who better to repair your machine than the people who built it?Unless anyone can recommend someone in the East Yorkshire area….
