Indesit ISL70C Condenser Dryer Help
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit ISL70C Condenser Dryer Help
  • #43967
    kirkie
    For some reason my dryer smells of burning and when you try to turn it on it sounds like water is swilling around. The drum will not turn, the fluff filter is clean and the water container empty…
    #279248
    helo_75
    sounds like the capacitor has failed
    the noise you can hear is the pump running
    is there a slight hum?
    #279249
    kirkie
    Re: Indesit ISL70C Condenser Dryer Help
    There is a slight hum. Is it an expensive fault and will it be cheaper to buy a new one?
    #279250
    helo_75
    nah its just the capacitor
    if you take the right hand side panle ( looking from the front) its right next to the motor
    part around £9 from online shop
    #279251
    kirkie
    helo_75 wrote:nah its just the capacitor
    I will take a look. Will I be able to see if that is the problem just by looking at it?
    #279252
    Very unlikely, it is possible to test with a meggar but TBH its cheap enough to take a punt on anyway.
    Would need serial number to identify correct part as both 7uf & 8uf capacitors have been used on these machines.
    kirkie
    iadom wrote:Very unlikely, it is possible to test with a meggar but TBH its cheap enough to take a punt on anyway.
    Cheers I will give it a go at the weekend…
    #279254
    kirkie
    I have looked for a Indesit ISL70C Capacitor on here and can’t find one. Can someone point me in the right direction please?
    #279255
    kirkie
    kirkie wrote:I have looked for a Indesit ISL70C Capacitor on here and can’t find one. Can someone point me in the right direction please?
    I have tried to turn it on this morning and it does nothing. All the lights come on, but no noise today….
    Thinking that I might just give it up as a bad jump and buy another….
    #279256
    Have you identified wether or not it is a 7uf or an 8uf capacitor yet. It will have this printed on the side.
