Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit ISL70C condenser dryer problems
- This topic has 8 replies, 5 voices, and was last updated 18 years, 2 months ago by
cassy.
February 3, 2008 at 8:53 pm #34307
cassy
Participanthi, in need of some advice. My indesit dryer is blowing cold air. I have cleaned filters ect. also my high heat button wont go on and just keeps beeping and flashing when pressed, could anyone advise me if this has something to do with the problem? i have looked in the manual for trouble shooting and theres nothing to help.
cheers cassyFebruary 3, 2008 at 9:39 pm #242115kelland
ParticipantRe: Indesit ISL70C condenser dryer problems
probably thermostat problem, happens to a lot of indesit/hotpoint/creda dryers….how old is it?
February 3, 2008 at 11:50 pm #242116cassy
hi, its only about a year and a half old, iv read a couple of posts about similar problems and i thought it maybe thermostat, dont really want the expense of a call out. Is this easy to fix? where is the thermostat located?
need specifics (female here ! lol) could poss get the help of a man tho.
thanks for you responseFebruary 4, 2008 at 11:08 am #242117helo_75
Participanttheres two different kind of heaters on that display
plug out first, take off rear fan cover, and the heater and stats are located on the inside, screwed to itis there 2 or 3?
u can get the stat kit im sure, available through the store
February 4, 2008 at 8:19 pm #242118cassy
Hi, ok iv took of what i think is the fan cover and inside it there are 4 coily things, remember female here ! is this what im looking for?
February 4, 2008 at 8:33 pm #242119cessna
That will be the heater elements you are looking at.
The thermostats will be the small round devices with wires running to them above the heater.You have to take out the tiny screws that hold the elements to the panel to gain access to the thermostats.February 4, 2008 at 8:49 pm #242120cassy
ya! think i located thermostats there are 3 of them, thought they would look burnt out or somthing but nothing to look at. What should i do now?
thanks for help!! (p.s havent unscrewed them or anything yet)February 7, 2008 at 9:21 pm #242121steve-o
you can get a stat kit for it,but the cause of the problem is more than likley that the condenser and float chamer are blocked with fluff . 🙂
February 7, 2008 at 10:35 pm #242122helo_75
Participantor maybe the starts just faulty
blocked condensers cause poor drying performance, they rarely cause stat failure
