Indesit ISL70C Condenser Tumble Dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit ISL70C Condenser Tumble Dryer
  • #37751
    kallen
    Hi everybody, having problems with my dryer can anyone help! here are the symptoms.
    My Indesit ISL70C Condenser Tumble Dryer has got a constant empty water light lit when the water tray is empty. When you select start it makes a short beebing noise then dryer does not start.
    I have tried switching it off and on.
    I cleaned the interior filter and the large one at the bottom.
    I took the water pump and floatation switch system at the back off and checked it and it semed fine unless a faulty switch.
    Then I took the top off (looking at the outside of the drum) and checked all the connections (power in etc) were secure.
    Thats about as far as im willing to go before things start getting broken even further!
    any help wil be greatly appreciated
    cheers guys
    Dan Simmonds 😀 😀
    #256266
    helo_75
    i reckon
    the pin to activate the door switch has fallen off
    open the door
    just above the door opening is a small hole.. on the door, in the same place should be a small shaft attatched to it which locates into the hole, activating the switch
    it could be bent, or missing!!
    proofs in the pudding… stick a screwdriver in the hole, then press start
    if it starts, its the pin thats the problem!!!
    let us know how u get on, please
    #256267
    kallen
    Helo….
    Thanks very much, you where spot on!! Did exactly what you said and voila, worked perfectly!!
    Cheers,
    Dan
