Indesit ISL70C fault code
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Indesit ISL70C fault code
  • #69075
    blackpoolfox
    Drier is turning on normally then after about 20 secs gives a beep, momentarily stops then starts running again with the power light flashing rapidly and the following lights blinking around once per sec – from left : time delay, alarm and empty water. The only light not flashing is the high heat light. If the drier is left to run in this state it continues to run but doesnt appear to get warm.
    Any assistance appreciated, thanks.
    #373625
    Re: Indesit ISL70C fault code
    Always best to give the flashing lights by number from top to bottom or left to right.
    Your error message is F13
    Rear NTC open or short circuit.
    #373626
    blackpoolfox
    Ok from left – 1,2,4 are flashing once/sec and power light flashing rapidly.
    Ok thanks any idea what kind of a job it is to fix this?
    Many thanks.
    #373627
    blackpoolfox
    Could you please also advise where this part is located inside the drier?
    Thanks.
    #373628
    Err, at the rear, behind the small back panel.
    The thermostats and NTC should be changed as a complete kit, two different types, one with a white NTC and one black.
    I would also remove the condensor from the bottom of the machine at the front. This should be cleaned out every week or so, if it is badly clogged up then that will lead to stat/ntc failure.
    Be sure to remove the mains plug before removing any panels.
    #373629
    blackpoolfox
    Ok we have taken the back off today, the 2 outer devices are black and the center one is white.
    What would I actually be asking for as a replacement would it be called a rear NTC kit?
    Also, are the 2 outer black devices the same, ie : does it matter which way around they go?
    Many thanks.
    #373630
    The thermostat kits come complete, they must be replaced in exactly the same position as the original ones.
    If your serial number is 51130.0000 or less you need C00208298 HERE
    If the serial number is 51130.0001 or higher you need kit C00208299.HERE
    #373631
    blackpoolfox
    Fitted replacement parts today and seems to have cleared the fault, many thanks for the info!
    #373632
    8)
    And if you are a Seasiders fan you are in the play offs as well. RESULT.
    #373633
    blackpoolfox
    Yeah indeed! good result 8)
