indesit isl70c wont dry on sensor settings
Home Forums Public Support Forums Help And Support Washing Machine Help Forum indesit isl70c wont dry on sensor settings
  • #49228
    anna9667
    Hello
    I have an indesit ISL70C tumble dryer. It won’t dry on the sensor settings. The program will last about 10-15 minutes before it stops, and the clothes are still wet. The dryer works on timer settings ok, just not on the sensor settings.
    Can anyone help.
    #299250
    helo_75
    depends on variant
    theres 2 designs, one has a band around the drum with a brush, the other has a sensor in the front baffle
    usually its the earlier ones that faulter.. usually the brush breaks, or the band becomes dislodged and the insulation breaks
    failing that, itll be the dreaded module fault
    #299251
    anna9667
    Re: indesit isl70c wont dry on sensor settings
    Thanks, Ive had the lid off and it has a metal strip that runs around the drum with a brush.. Would you say the brush is at fault or the metal strip, any suggestion would be appreciated.
    #299252
    helo_75
    there should be some sort of insulation between the drum and the band… often, the insulation slips out, and the band touches the drum, which it shouldnt
    #299253
    anna9667
    Billiant, that has happened. There is a plastic sheet under the metal strip which has come out in places, i will start there. Thank you very much and I will post whether It was succesul or not.
    #299254
    anna9667
    Unfortunatley that has not worked, any other suggestions would be greatly appreciated
    #299255
    helo_75
    pushing it back in wont work
    u need to take a multimeter and check if theres continuity between the band and tthe drum
    if there is, then it wont function correctly
    trust me, thats ur problem, its a pig to sort, even indesit changed the way it worked it was such an issue
    #299256
    gandh1
    before anyone says anything, i know im being cheeky here, but is this the same problem with all merloni-brand sensor dryers with drum sensor bands? and could it throw up a f-15 error on lcd display dryers?!
    *cheesey innocent grin*
    #299257
    helo_75
    time you applied for trade access mr gandhi sir!!
    your missing out.. join us, we wont bite!
