Drier Indesit isl70cx is turning on normally, then after about 20 secs gives a beep, momentarily stops then starts running again with the power light flashing rapidly and the following lights blinking around once per sec – from left : (1) time delay and (3) high heat.
If the drier is left to run in this state it continues to run but doesnt appear to get warm.
By the way the Machine has 3 thermostats over the heater and they all looking good.
F10, the safety stat above the heater has failed. Usually caused by blocked filters or condensor, stopping the machine mid cycle whilst still hot or loose fan.
Stats come as a set of three, safety stat, cycling stat and ntc.
Two different kits used, depends which ntc you have one is black and the other white.
