Indesit IWB5113 Drain hose Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit IWB5113 Drain hose This topic has 9 replies, 2 voices, and was last updated 12 years, 1 month ago by john_r06. Viewing 10 posts - 1 through 10 (of 10 total) Author Posts March 2, 2014 at 8:06 pm #79781 john_r06Participant The drain hose has started to decay and leak on the section closest to the trap. I have got a replacement but wondering how to go about getting access to connect it. I am assuming this will be at the front and bottom of the machine? Thanks in advance March 3, 2014 at 5:05 pm #410594 MartinParticipant Re: Indesit IWB5113 Drain hose john_r06 wrote:I am assuming this will be at the front and bottom of the machine? Spot on there John, go for it. :tup: March 3, 2014 at 8:31 pm #410595 john_r06Participant Re: Indesit IWB5113 Drain hose Thanks …. How do i get access to connect the drain hose the easiest? March 3, 2014 at 9:50 pm #410596 MartinParticipant Re: Indesit IWB5113 Drain hose john_r06 wrote:Thanks …. How do i get access to connect the drain hose the easiest? Rest the machine at an angle of 45 degrees on its right hand side (looking at it from the front) then access underneath. March 3, 2014 at 10:09 pm #410597 john_r06Participant Re: Indesit IWB5113 Drain hose So you don’t need to remove any panels or top of the machine to replace the drain hose? Thanks for you assistance so far 😀 March 3, 2014 at 10:17 pm #410598 MartinParticipant Indesit IWB5113 Drain hose Start from where I suggest and the procedure will be all too obvious. 🙂 March 4, 2014 at 12:37 am #410599 john_r06Participant Re: Indesit IWB5113 Drain hose Okay for ease can I just lay the appliance on its right hand side? March 4, 2014 at 8:31 am #410600 MartinParticipant Re: Indesit IWB5113 Drain hose john_r06 wrote:Okay for ease can I just lay the appliance on its right hand side? Yes but as I said earlier, only at an angle of 45 degrees. (Lean it on something) March 8, 2014 at 1:55 pm #410601 john_r06Participant Re: Indesit IWB5113 Drain hose Ah okay I won’t tip it right over. Replacement drain hose has arrived but as I won’t be home till tomorrow I can’t have a look. Does the hose screw on? From parts list I notice a metal clip in this area also, is this east to remove and put back on? Thanks for all your help. March 8, 2014 at 4:25 pm #410602 MartinParticipant Re: Indesit IWB5113 Drain hose For a guy of your calibre and with a few basic tools you are on to a winner, easy! Author Posts Viewing 10 posts - 1 through 10 (of 10 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
