Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit IWB5113 Washing Machine Flashing Lights after 5 mins
- This topic has 9 replies, 2 voices, and was last updated 12 years, 11 months ago by
kartnkrazy.
May 5, 2013 at 8:31 pm #75321
kartnkrazy
ParticipantMy Indesit Washing Machine IWB5113 has a strange fault.
When turned on at the mains there are no lights at all, and all buttons are unresponsive. After almost exactly 5 minutes the horizontal row of lights start flashing and the 3rd and 4th vertical lights from the top (spin and drain lights) come on steady. The buttons remain totally unresponsive, however. I hope someone can help me diagnose this error. See video on youtube: http://www.youtube.com/watch?v=jzLsWpR0qo0
Thanks in advance for any assistance! 😀
May 5, 2013 at 8:56 pm #394550iadom
ModeratorRe: Indesit IWB5113 Washing Machine Flashing Lights after 5
Error codes on these are from top to bottom, that still looks to be 3+4 from the bottom, or F12. That is a communications error. If you are very lucky it may just be loose connections between the pcb’s. You need to remove the mains plug and squeeze the connector blocks on the circuit boards.
You have to bear in mind that Indesit have some of the weakest electronics on the market so it could be a faulty pcb.
Sent from my iPad using Tapatalk HDMay 5, 2013 at 9:02 pm #394551kartnkrazy
ParticipantRe: Indesit IWB5113 Washing Machine Flashing Lights after 5
iadom wrote:Error codes on these are from top to bottom, that still looks to be 3+4 from the bottom, or F12. That is a communications error. If you are very lucky it may just be loose connections between the pcb’s. You need to remove the mains plug and squeeze the connector blocks on the circuit boards.
Sent from my iPad using Tapatalk HDThanks for the quick reply Iadom. I have already removed the control board and checked all the connectors and found nothing obvious. I will have another go, but thanks again for your answer.
May 5, 2013 at 9:26 pm #394552iadom
What about the main pcb?
Sent from my iPad using Tapatalk HDMay 5, 2013 at 10:07 pm #394553kartnkrazy
iadom wrote:What about the main pcb?
Sent from my iPad using Tapatalk HDBy “main pcb” do you mean the pcb in the Control Module with the service engineer’s diagnostic port? This module has a label with the code:215010229.01 SW:01.04.03 on it.
I have taken this board out, checked for faulty electrolytic capacitors (which I read is a common fault on some similar boards) and then put it back in again, but the same fault recurred. If it is a communications error, what else does this board communicate with? I presume it just communicates with the pcb on the front control control panel (which houses the push buttons and LEDs)?
I have connected and disconnected most connectors now but still to no avail. Thanks again for taking the trouble to try to help!
May 6, 2013 at 7:26 am #394554iadom
The main pcb is the one in the base. Diagnostics on these can only be run with a company engineers laptop and a smart card adaptor.
The very limited info that we have says check all wiring connections, then change the main pcb, then if that doesn’t work the display/facia pcb.
It may be covered under their five year parts warranty.
May 6, 2013 at 7:48 am #394555kartnkrazy
iadom wrote:The main pcb is the one in the base. Diagnostics on these can only be run with a company engineers laptop and a smart card adaptor.
It is covered under the 5 year parts guarantee but Indesit still charge a fortune for an engineer callout – more than the machine is worth. I’ll check the display/facia pcb for any obvious errors. Failing that I will try to pick up a new control module cheap off ebay. My Hotpoint machine also failed with a main pcb fault. It seems Hotpoint and Indesit machines are built with really flaky electronics that fail just out of wararnty! I’ll never buy another machine from either brand! Thanks for your advice; much appreciated.
May 6, 2013 at 8:13 am #394556iadom
The new pcb will need to be programmed of course, smart card and card reader needed to achieve that unless you send it to the likes of EMW to test although certain faults don’t show up on their tests.
May 7, 2013 at 9:19 pm #394557kartnkrazy
I don’t know EMW – do you have their contact details by any chance? Many thanks again.
May 7, 2013 at 9:38 pm #394558iadom
A quick Google will find them.;)
