Indesit IWB6123
  • #93083
    rickard
    Went to this Indesit IWB6123UK 46663900000 it would take water in for about 30 seconds and then stop bring the drain pump on and all the horizontal lights flash rapidly the only way to stop it was to disconnect the power, Also when tried on spin it would not get to full spin but again after about 2 minutes stop and flash all the horizontal lights. spoke to EMW who said change board and interlock which I have done but on testing still doing same fault, I have disconnected all components and tested insulation. any help would be much appreciated. Andy
    #453178
    Re: Indesit IWB6123
    As per the Known Error Codes thread.
    The flashing lights are not an error code, they just indicate that an error has occurred.
    The bottom five VERTICAL lights on the far right are used to indicate errors, these lights do not flash but are on steady.
    The lights are numbered from BOTTOM to TOP, bottom light is 1 and so on.
    If you look in the known error codes thread all the fault codes for this machine are there.
    #453179
    rickard
    Re: Indesit IWB6123
    Thanks Iadom for your quick reply but none of the vertical lights are on when it happens just the horizontal lights flashing quickly. Thanks
    Andy
    #453180
    kaibart
    Re: Indesit IWB6123
    Board fault emw repairs I’ve had in the past had given me so much bother I don’t use them anymore
    #453181
    Grendal
    Re: Indesit IWB6123
    Def a board fault had it a few times
