Indesit IWB71250 (UK) No Fill
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit IWB71250 (UK) No Fill
  • #75988
    Bernie
    Indesit IWB71250 (UK) 30761848700
    Machine is 18 months old, customer used 90deg wash for the 1st time, when they came back all the leds were flashing they could not get the machine to drain, did drain it by dropping hose into bucket. Now will not fill.
    Spins but pump does not run, pump runs on drain.
    Will not fill on any fill program, pump just runs.
    No flashing leds, no fault code
    Pressure switch clicks when blown into, valves test ok.
    Any body have any suggestions.
    Bernie
    #396875
    Re: Indesit IWB71250 (UK) No Fill
    What state is the heater in?
    #396876
    Bernie
    Thanks for the reply Martin
    I did not test it!
    Bernie
    #396877
    Bernie wrote:I did not test it!
    Thank you for your confession my son, go forth with your god armed this time with your Megger…….Aaaaaamen!
    #396878
    Bernie
    Thanks Martin
    Will give it a go
    Bernie
    #396879
    Bernie
    Just been back heater is ok – 31ohm, Insulation 999 meg ohms
    Am I now looking at a replacement board?
    Any other suggestions please
    Bernie
    #396880
    sce
    A melted 1x inlet valve coil?
