Indesit IWB71251 ECOUK (8085068095) Motor/Board Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit IWB71251 ECOUK (8085068095) Motor/Board This topic has 4 replies, 3 voices, and was last updated 4 years, 7 months ago by jontymox. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts September 8, 2021 at 7:49 pm #100016 jontymoxParticipant Good evening all, The above washing machine will not wash/agitate on a wash cycle, yet will perform perfectly on a spin cycle. Not sure how to conclusively test the motor or board for such a fault, and wonder if this is a known problem? I realise there are other electronic specialists, and I may well have sent the board to the now closed EMW Electronics for testing…. jonty September 8, 2021 at 7:58 pm #478906 jontymoxParticipant p.s. I did check the motor brushes, and the wiring to and from the motor but had to get to another job! September 8, 2021 at 8:41 pm #478907 Hollytree_TechnicalParticipant As long as the insulation resistance on the motor is good then the mere fact that it spins correctly means that the motor is good and that you will be looking at a board fault. Jem September 8, 2021 at 10:39 pm #478908 electrofixModerator bit of a long shot have you checked the board for bad relay solder joints can you hear the relays clicking as the relays change as the motor is supposed to be reversing Dave September 9, 2021 at 6:47 am #478909 jontymoxParticipant Thanks for your help gents, No, I didn’t have time to visually check the board. However, I’m pretty sure there’s no clicking from the relay… Will return and test further. Thanks again. Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
