Indesit IWC81251 Constant filling
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit IWC81251 Constant filling
  • #93659
    sllimeel
    The problem is the machine fills constantly. I disconnected the fill valve electrically and it shuts off. When reconnected the machine fills and the drum agitates. The drain pump operates when the drum starts to overfill, all the time the water is running into the drum. Something is holding the fill valve open ….. pressure switch?
    #455160
    Re: Indesit IWC81251 Constant filling
    when does it start to fill, as soon as you turn on or after you select and start a programme ?
    if you pause the programme does it still fill or does it stop ?
    sllimeel
    As soon as you start the programme it fills as it should.
    When you pause the programme is still fills.
    #455162
    In that case it sounds like the control board
    most components in the machine are controlled by the board using electronic switches called triacs. The triac that controls the valve sounds like its failed and needs to be replaced. Anyone who has a knowledge of electronics and soldering could do it all that needs to be done is find the faulty one and fine a replacement
    if you don’t feel up to it contact
    http://www.qer.biz/servReps.htm
    and see if they can look at the board and test for this fault
    sllimeel
    Hi Dave
    Thanks for your advice.
    This machine is at our holiday home in France and seems to be a European model, not a UK one. Could you advise where to buy a new Control board online if required. This way i could take it over to France on my next visit and swap it out.
    #455164
    problem with indesit is the boards come blank and have to be programmed in the machine. I cant do one without purchasing a programmer and the software to do it
    so its not a amateur repair in fact its not a easy repair for anyone except the
    manufacturer or someone who can change electronic components on the board
    where was the machine bought ?
    sllimeel
    In France
    #455166
    don
    Looks like you may have to bite the bullet and go to Hotpoint direct in France.
    Don
    #455167
    sllimeel
    If I remove the board can I get the triac repaired and replace when I return?
    #455168
    as long as that is the problem yes can be done
    part is cheap at only a few pounds
    if you remove board and put same board back after repair then it does not need programming
    I also assume you have checked guarantee. I assume it the same as uk and covered for 12 months but I cant read French to check
    sllimeel
    It is a couple of years old now but only used a few times a year, so out of warranty.
    I’ve removed the board and will take it back with to the UK and get it tested.
    I’m back in July…so hopefully I can bring the repaired board back and plug it in!
