Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit IWD7145s not progressing through cycle
- This topic has 11 replies, 4 voices, and was last updated 11 years ago by
robodoc43.
March 11, 2015 at 4:34 pm #84371
robodoc43
ParticipantMachine has just been moved. Allegedly was working before. Now it will start a program, water goes in drum moves a couple of times and then just sits there. Time counts down but nothing else happens. Can move manually to drain and will pump out. Heater checks out OK. No error codes. Anyone have any thoughts?
March 11, 2015 at 11:36 pm #425493gandh1
ParticipantRe: Indesit IWD7145s not progressing through cycle
what does it do when you try spin only ? and are you trade ?
March 12, 2015 at 9:37 am #425494robodoc43
Hello gandh1, same sort of thing – makes an initial couple of spins but then just sits there and no I am not trade just a frustrated grandfather trying to sort out granddaughter’s machine. Any help greatly appreciated.
March 20, 2015 at 1:33 am #425495gandh1
if it has been trolleyed during its move id be looking for damage to wiring around the motor area, rear bottom edge of indesit carcasses lend themselves to pivoting on the base of a trolley, causing front edge of narrow widthed trolley lips to swivel up and hit motor. sounds like a tacho or tacho cable fault on motor. under no circumstances inspect this whilst the appliance is live. i.e plugged in and power on. you will need a multimeter to check the motor / wiring looms
March 31, 2015 at 2:37 pm #425496robodoc43
gandh1 thanks for the suggestion sorry I did not pick it up until now. I’ll get a look at the machine later in the week but one question – should I not be seeing an error code?
April 3, 2015 at 8:28 pm #425497gandh1
its an indesit, if the electronics worked properly, half of them with this kind of issue wouldnt have been scrapped…
April 5, 2015 at 5:04 pm #425498madangler1
Is it three phase machine by any chance? I have found a very odd thing on the later Arcadia Indesit boards. If the tacho signal is missing it will start, tumble a few times then stop and count down. On the older stuff the motor would just rev but on the new stuff it tumbles just a few times then stops. Also the tumble speed is a little quicker than normal. I spent hours on one doing this one days and found the tacho wires were damaged at the motor. Have seen it several times since.
Check the motor wiring.
April 5, 2015 at 6:19 pm #425499iadom
ModeratorRe: Indesit IWD7145s not progressing through cycle
Almost 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain it’s a brush gear motor. 😉
April 5, 2015 at 6:30 pm #425500madangler1
Worth checking it anyhow Iv only seen it on the 3ph machines but it’s not to say it won’t be the same on brushed motors.
April 5, 2015 at 8:06 pm #425501robodoc43
yes its definitely a brush machine and they are OK. I’ll take a look at the wiring tomorrow. Thanks for the continuing interest.
April 6, 2015 at 9:08 pm #425502robodoc43
checked out the motor and tacho and associated wiring.all OK. looks like its the controller unless somebody out there has any bright ideas.
April 13, 2015 at 9:41 pm #425503robodoc43
ParticipantRe: Indesit IWD7145s not progresatesing through cycle
update: got a replacement board and fitted it last night. Started a program which got as far as the spin and stuck.program will progress with no spin in cycle but a spin in the cycle seems to block it-no error code but will not count down. able to empty by moving to that setting then tried to get it to spin. drum turns but not at spin speed and timer does not progress so something is blocking the spin phase. anyone able to help?
