indesit IWD7168 F06
  • #71041
    wilf
    can find no obvious fault fills wash heat pump and spin but comes up F06 at end of cycle have to switch off to clear it.
    induction motor machine, insulation resistances ok
    any ideas?
    wilf
    #379864
    Criscold
    Re: indesit IWD7168 F06
    F06 Door lock fails to close / open, door lock PTC triac open
    / closed,
    mains frequency signalfault, mains power signal fault
    – Check for water leaks that may affect connectors J004 or J11
    (three-phase) causing the relative contacts to short;
    – Check Door lock terminal board (any problems due to
    aggression caused by manufacturing chemical residues that may
    cause short circuits);
    – Check J004 / door lock wiring;
    – Check door lock;
    – Renew PCB.
    #379865
    wilf wrote:
    any ideas?
    Error Codes thread 😉
    #379866
    wilf
    thanks I’ll check that
    wilf
    #379867
    wilf
    door lock sorted it
    thanks wilf
