Indesit IWDC6105
  • #65161
    AMS
    Hi all,
    Does anyone have a wiring diagram for this machine? In particular the wiring to the interlock. Customer bought one of these second hand in “good working condition” He called me out when it didn’t work. Found that the interlock plug had burnt out and someone had cut the plug off. There is a red wire, which is no problem as I can see where it goes, but the 2 brown wires are the problem. As far as I can tell, 1 is live and the other neutral. But to what terminals do they connect to the interlock?
    Cheers,
    Re: Indesit IWDC6105
    you can work out most interlock connections
    you need a meter and a plug and lead with 2 terminal to connect to lock
    use meter to find which terminals are the heater
    the one i have here is an old hoover one and the heater is terminals 1 and 3
    connect lead to these terminals and plug in
    when lock has powered slide lock mech till it locks
    unplug mains and using a meter fing out which two terminal are now short circuit
    with my lock its terms 3 and 2
    now on my lock your red wire will go on term 1
    after that the other 2 dont matter but only 1 way will work
    the red may supply a live or neutral to the lock to energise so as long as this wire is in the right position you wont blow the machine
    you say that one brown wire is live and the other is neutral but in actual fact one wire is live and the other is the switch wire that becomes live after the lock closes
    hope this helps
    Or you could just check your PM’s 😉
    #359325
    AMS
    Thanks for the replies guys, that should give me plenty to go on.
