Symthoms
The machne will fill and wash no problem
When set to drain or spin the drain pump will run for 1 second only – no further voltage to the drain pump
I have changed the module and the same result
Would any one be able to advise me on this
Many thanks
Declan 😀
Hi Tim – thanks for your advice
I checked the continuity of the wiring from the dryer probe ntc to the module – all intact and reads correctly
I connected the ntc dryer wiring to another spare dryer unit
unfortunately the problem still persists
Thanks Hotgog
I swapped out the pressure switch with another , unfortunately the problem still persists ( pumps for about 1 second and then nothing)
This is good to know about the presure switches for the future
I appreciatte your advice
Thanks Declan 😀
just thought if you change main board you sometimes have to change console mod wiring if you only have 4 cable harness at the console it needs to be converted to a 5 cable harness
Thanks Hotdogs..I initially thought that might be the problem, I went back to read the technical notes re the 5 wire harness to the console.. My machine is the later model with 5 wires.thanks for your help Declan 🙂
