Re: Indesit IWDC6105UK Washer dryer 4th light error.
Thanks for the info iodom, I did look for the error in the fault code section under the help menu. I assumed this would have had all the known error codes. I also done a search for the code in the forums but the couldn’t find anything relevant.
Martin:
The ‘known error codes’ thread is not a secret, but not having the same information in the error codes under the help menu is.
so now you don’t need to wonder!
When in a customers, trawling throungh 138 posts to find a fault on a smartphone with a limited connection is not ideal but now I know the information in the error code thread is more comprehensive I will look there first.
