Indesit IWDC6125
  • #96628
    Confusedbydefault
    My Indesit washer dryer IWDC6125 was on whilst the circuits were tripped. It now refuses to work through any cycle properly and ALL lights flash continuously, it fills but won’t drain and the only way to stop it is to turn it off at the mains.
    I’m looking for some idea of what might be wrong so I’m a bit more clued up before someone comes to look at it really. A rough idea of its its fixable or if I’m likely to be looking at replacing would be good too, just so I’m prepared. This site’s guide has suggested an F15 fault.
    The machine is only 2.5 years old. The manual doesn’t help at all and neither does the Indesit site.
    Thanks in advance
    #464207
    are all the leds flashing or only some of them ?
    if you set the machine on drain will it just drain ?
    Confusedbydefault
    All lights are flashing across the top horizontal row (ECO time etc). The lights in a row on the right (vertical, 3h, 6h, 9h etc) are static.
    It refuses to drain, if we can get it to drain it automatically tries to refill.
    The site says the photos I’ve tried to take are too big to upload.
    #464209
    host the photo on another site and post a public link
    Confusedbydefault
    I think it might have worked. Flashing lights along top and static down side.
    #464211
    yes that’s F15
    check the dryer heater element would be my next try
    Confusedbydefault
    At least I can direct someone when they come out. Do you think it is a very expensive fault to fix, am I going to be looking at replacing the whole washer/dryer? Thank you for replying.
    #464213
    difficult to say at the moment may just be a faulty element
    Confusedbydefault
    Thanks, fingers crossed it’s not too expensive to fix.
