Indesit IWDC6125 dryer question
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit IWDC6125 dryer question
  • #97847
    snig
    I’m getting F15 dryer relay fault on this machine. Found o/c dryer element but fault code comes up on any programme. Does it sense element even when not in use or is it a module fault as well ?
    #469794
    very possibly element. you should have put something across the element wires to check. Have often wired the element wires to the fan motor so machine can be used
    snig
    Yes, i did think of that, After i had left. Seems unlucky if she had two faults but we all know it can happen.
    #469796
    snig
    Returned with new element which sorted problem but found the dryer fan had melted badly. Have ordered a replacement ( which is metal i believe ) but wondered if this is a common problem.
