Indesit IWDC6125UK
The four LED’s along the top and the start/pause led are flashing constantly.
Starts to fill then led’s flash, ok on rinse, spin and dryer. Meggered motor and heater both have a very good reading.
I did get it to wash by filling it on rinse cancel then select program heated and washed for 3-4 mins then LED’s started to flash and pump running.
Any suggestion please
Bernie
Re: Indesit IWDC6125UK LED’s along the top flashing
Thanks for the reply idaom.
There were no vertical lights flashing. Just the option buttons along the top.
I was wondering if this machine has the same fault codes as the WIDL washer dryers which use the options buttons, i.e. F15 Drying Relay – check heater relay I assume the PCB is US.
