Re: Indesit IWDC6143 intermittent pump failure
Worn pumps can work intermittently but your machine would have had to have been used excessively for yours to be that badly worn, but then it is an Indesit after all. 🙁
The electronics are sometimes a bit ticklish on these, as is the water level switch.
I know you say the pump impellor will turn, but does it have any ‘side to side’ movement. If it has, even a small amount then it will seize intermittently.
